G'day mate.
I hope I'm doing this in the right place, I've got a 4age engine that I'm rebuilding and I've got some ARP high compression pistons that are 12:1 ratio and I'm looking at a set of quad-throttle bodies some upgraded cams and what-not and I'm just wondering if the standard ecu would be able to handle all this of if I should scrap it and upgrade?
cheers.
Upgrade. If you want to get the best out of your mods, upgrade.
Also, what 4AGE, I'm guessing a big or smallport? You'll need to run aftermarket engine management with quad throttles no matter what.
aww yea. fair enough. big port.
is there any management system that you would recomend? or should I shop around?
cheers for your help, much appreaciated
Littleredspirit might chime in.
He has had extensive experience tuning his silvertop 20V, which is pretty silmiar to what yours will become once you put the quads onto the bigport.
