niland Posted June 26, 2013 Report Posted June 26, 2013 Picking up a front end damaged KE50 tomorrow and am going to part it out before it hits the Scrap metal yard just wondering if anything will fit into a KE10 for example Manual Pedal Box--is the clutch cable interchangable? Front Struts Brakes Diff etc. If your after anything from it let me know the car is complete besides the front end damage has the tacho dash and rarer steering wheel from the ke50, I assume this is interchangeable between the ke30/35/55 am I correct? Quote
Bamboo Posted June 26, 2013 Report Posted June 26, 2013 It's basically a ke30 mechanically. Do you have the rear wiper assembly? Bamboo Quote
B.L.Z.BUB Posted June 26, 2013 Report Posted June 26, 2013 You should be able to use the disc brakes, good upgrade. Its just a matter of mix and matching the wheel bearings from memory. Add an early Mazda dual circut master cylinder and your KE10 will actually stop. Quote
Bamboo Posted June 26, 2013 Report Posted June 26, 2013 (edited) Oh and has the Jap diff which can update the stud pattern to 114.3 on a ke 20 axle housing Edited June 26, 2013 by Bamboo Quote
tojo2 Posted June 26, 2013 Report Posted June 26, 2013 (edited) If the struts have decent inserts they can be used in the ke10 struts for slight lowering Theres a howto by Felix somewhere Steeringwheel looks the same as a ke35 item U series diff head fits in the B series ke10 diffhousing Edited June 26, 2013 by tojo2 Quote
B.L.Z.BUB Posted June 26, 2013 Report Posted June 26, 2013 Oh spring hats, instant 2" lowering. Quote
niland Posted June 26, 2013 Author Report Posted June 26, 2013 On 6/26/2013 at 9:33 AM, Bamboo said: It's basically a ke30 mechanically. Do you have the rear wiper assembly? Bamboo pick the car up tomorrow will let ya know Quote
Bamboo Posted June 26, 2013 Report Posted June 26, 2013 Thanks. I've got an early ke50 without the wiper and I've been a searching. Bamboo Quote
cherryE10 Posted February 20, 2014 Report Posted February 20, 2014 still got the dash? sorry for being late. just picking up a ke50 on Monday Quote
philbey Posted February 22, 2014 Report Posted February 22, 2014 I don't think the spring hat switch works with ke30/50 parts does it? Quote
