A third option could be a leaking windscreen seal - AE92s are fairly well known for rust around the windscreen (often not always visible until it gets bad), if water leaks behind the seal into the A-pillar then it could funnel down into the footwell. Rip as much of the carpet/dash and a-pillar panels out as you can (within reason), sit in the footwell and get someone to spray the car with a hose, and see if you can see water leaking in somewhere.
