post-18012-0-47773200-1369872582.jpghey, ive got a 4K with a 5 speed, and there is a small leak from where the trans bolts to the engine. not sure what it could be. could someone please help me. is there some sort of seal that could need replacing? thank you :) Edited by My38
yeah gotta take the gearbox out, flywheel and clutch off.
The rear main seal sits around the crankshaft and seals against crank case.
i dunno what engine this is, but the 4k will look pretty simliar
http://forums.pelicanparts.com/uploads18/Rear+Main+seal+depth+just+below+bevel+marked+in+red+Photo+credit+Tyro+Rennlist1299935335.jpg
The thing in the middle with all the bolt holes is the crank shaft (bolt holes are flywheel bolt holes). and the rubber thing around the edge is the seal you replace.
howeever, be VERY carecful you do not scratch the crankshaft surface, or the block surface, or you will never get it to seal.
http://www.rollaclub.com/board/topic/26273-how-to-remove-front-and-rear-main-seals-on-4k/
if you don't have an engine manual, get one! they are really good for stuff like this.
thank a lot :) ill take the gear box out when I have time and sus it out :) it should be alight to drive with it like it is though??
Used gear oil stinks.
But honestly you have way more of a chance it being a rear main crank seal than a gearbox plate crack.
Didn't mean to alarm you just saying I'd seen it before.
Yeh I'm guessing that would be the case! Do you know where I would be able to buy a new one?
