my daily might not be so daily now....
twin 40DCOE webers
290/295 cam with .453 lift comp cams regrind.
spool H beam forged rods
ARP rod bolts
20" over bore pistons
11.63 compression
dual valve springs
roll master timing chain and sprockets
special modded sump.
the original flywheel has gone from 7.25kg to 5.5kg.
3k head with valve stem seal update
full bottom end balanced
block decked and honed
exedy heavy duty clutch.
crane cams xr3000 electronic optical ignition conversion, using 7M coil.
regraphed distributor
shimmed oil pump
extractors
redline dual carbie intake manifold
redline filter socks (to be replaced with twin oval filters)
rev's to eight...but only because any higher and the i risk cracking the block, if i have to rebuild again one day I will partial grout fill it, and it might need a bigger muffler.
I thought the fact it only makes 70hp at the wheels would be a bad thing but it's one of the most fun cars i have ever owned.
things on the do to list :
new filters
new exhaust.
retune
this video was of the old 5k that was in it, i was test fitting the carbie's and the electronic ignition.
more vids to come along with pics
Edited by Farch
Nice! What's it like around town and at traffic lights... that annoying "under 3000rpm" driving?
Well it doesn't' come on till 3500 rpm and the cam runs out at 7500. But because the engine has 11.63 compression it's not too bad. But the idle's heaven.
Edited by Farch
  • 9 months later...
now has 16mm ram tube instead of the stocks (75 mm i think). since replacing the throttle linkage with a simple balance lever and getting rid off some air leaks the engine has shown one of symtoms of having too high comp and massive cams where the engine self accelerates when light throttle is applied then removed. Lowering the idle screw then resetting again gets it at the correct idle speed then as soon as you apply any throttle it will self feed again after. loading the engine up with the clutch to lower the rpm will also work to get it running at correct speed. apparently the only fix for this is to drill a small hole of the correct size in the throttle butterfly of each carbie so the butterfly then sits flat against the stop with no idle screwed in, the drilled hole should be controlling the idle. Only down side is i won't be to able modify the idle speed at all once set.
have got this right? now if it only had brakes......
