Tough_little_ke20 Posted February 27, 2014 Author Report Posted February 27, 2014 Went backwards tonight and started hacking again, turned 2 holes into 1 now I can reform the chassis but run it into the cab rather than underneith in the way of the subframe then gusset them to the subframe mounts and sheet the rest off Quote
Tough_little_ke20 Posted March 3, 2014 Author Report Posted March 3, 2014 Sandblaster dropped the sub frames in today, looks better now Quote
Tough_little_ke20 Posted March 5, 2014 Author Report Posted March 5, 2014 Diff is all painted, looks brand new Quote
Tough_little_ke20 Posted March 7, 2014 Author Report Posted March 7, 2014 Rebuilt the chassis into the cab today Quote
Doogs Posted March 9, 2014 Report Posted March 9, 2014 Cool project mate, love your work! What ECU do you plan on running? Quote
Tough_little_ke20 Posted March 9, 2014 Author Report Posted March 9, 2014 Cheers, I'm still not sure on that one, I might run the standard computer for a little bit and see how it goes power wise and when I wanna crank it up a bit put an aftermarket ecu, I don't know what is the best for a 3s but I suppose really they're all the same, if it gets a new ecu I will be able to run coil packs, and up the boost and hopefully run about 220rwkw safely Quote
Doogs Posted March 11, 2014 Report Posted March 11, 2014 On 3/9/2014 at 11:17 AM, Tough_little_ke20 said: Cheers, I'm still not sure on that one, I might run the standard computer for a little bit and see how it goes power wise and when I wanna crank it up a bit put an aftermarket ecu, I don't know what is the best for a 3s but I suppose really they're all the same, if it gets a new ecu I will be able to run coil packs, and up the boost and hopefully run about 220rwkw safely Sweet, fair enough. It is unfortunate that Toyota has no Nistune equivalent, it's generally a pretty big expense if you want to tune or change the ECU on a Toyota motor! Quote
SpicemanSteve Posted March 11, 2014 Report Posted March 11, 2014 On 8/19/2013 at 12:31 AM, orangeLJ said: LOVE the trailer! X20. Awesome an skills man! Quote
Tough_little_ke20 Posted March 11, 2014 Author Report Posted March 11, 2014 Bit more welding and I'm ready to paint Quote
Tough_little_ke20 Posted March 18, 2014 Author Report Posted March 18, 2014 Got the rails completely welded tonight and the floor is tacked in, I'll weld it up tomorrow Quote
Rafael Posted March 20, 2014 Report Posted March 20, 2014 Do u know no one that got a right hand drive dashboard I'm trying to convert mines Quote
Tough_little_ke20 Posted March 22, 2014 Author Report Posted March 22, 2014 Nah mate sorry can't help you there, best way is search google and eBay you'll find one somewhere Quote
Tough_little_ke20 Posted March 23, 2014 Author Report Posted March 23, 2014 Got the front mounts all gusseted today and fixed the rust in the chassis, getting close now. Couple of holes to fill, fix the rust in the back, finish the seam welding the paint it Quote
Tough_little_ke20 Posted March 25, 2014 Author Report Posted March 25, 2014 Changed the mounts a little, now the load is spread over 2 different points not all just on the base of the mount Quote
