jader Posted May 17, 2013 Report Posted May 17, 2013 Hi all,was hoping to get some advice on a problem with what appears to be a gasket that goes between the inlet and exhaust manifolds which is partly missing (see photo). I have heard that you can get some exhaust repair paste that could potentially be a quick fix, but thought i would see if anyone else has had issues with this before (i haven't been able to find much info on this gasket, even the workshop manual i have doesn't seem to mention it in the inlet/exhaust manifold section). Thanks in advance Quote
GJM85 Posted May 17, 2013 Report Posted May 17, 2013 (edited) You can get a steel gasket from most exaust shops. Edited May 17, 2013 by GJM85 Quote
GJM85 Posted May 17, 2013 Report Posted May 17, 2013 (edited) You can also go to the exaust shop and get some extractors. Edited May 17, 2013 by GJM85 Quote
Taz_Rx Posted May 18, 2013 Report Posted May 18, 2013 Its called the hot box gasket. Be careful removing the bolts that hold them together, they have a tenancy to snap! Quote
jader Posted June 2, 2013 Author Report Posted June 2, 2013 thanks for the advice guys.Not looking forward to trying those bolts, ill see how i go. Quote
LITEACE82 Posted July 2, 2013 Report Posted July 2, 2013 I use the gasket available at AUTOBARN, They have metal corners; ACE! BTW TOYODIY.COM real helpful. Quote
