Yes, but only if you add a better exhaust at the same time. don't expect 'OMG ITS LIKE A TURBO' power increases but there will be a SMALL increase in power.
Add a cam grind, a carbie, some basic head work and you'll get it pretty peppy but nothing amazing.
I would go as far to say; not really. Even with an exhaust, you'll still have the same amount of slows but will feel faster because you ear-dyno tells you it's faster!
But chuck on the cams and carb upgrade, now you're talking.
lol- philbey is right! The ear-dyno is all that matters!
Note how everyone said new 'exhaust' when you asked about new 'extractors'?? The extractors will cost you $200-250 for new 4-into-1 style that terminate in a 2" pipe. Then add the cost of a 2" pipe into a 2" resonator under the passenger's floor, then a complete 1.75" pipe and muffler to the back. The exhaust cost me $350 on top of the extractors..
Works well and sounds nice. It goes with the twin SU carbs and the Crow cam, with a head skim and a bit of port machining. Its nothing compared to any modern car, but it is how the 4K should have come out!
Plan the whole rebuild and modification job you want to do over the next year or two, and decide what you can afford. Then work out the order of doing stuff, as some of it means engine out and some is just a bolt-on.
just a quick question guys.. ive been on the hunt for a while and can't find a set of extractors for my k engine. Nothing on ebay or here at the moment, where do you find a set? (QLD)
Tomorrow I'm going to install some 4-1 extractors on my little suzuki 1.3L and just weld it up to the biggest muffler i can find at the wreckers.
So ill tell you if it makes any difference.
I suspect it will make no difference, appart from looking cool in my engine bay:D (and for $40 + welding wire, thats good enough for me!)
Have to agree i put extractors and 2'' on my 20 didn't really make much difference feels a little less choked thats about it
bigger cam stroker kit and extractors with a 2'' exhaust thru to sports muffler
What carb are you chasing to go with this setup?? Can you find a 32/36 Weber downdraught, or even better a single DCOE Weber?? That will make a big difference once you have the exhaust and cam in.
