Hi All, I've so far dismantalled the front of my ke20. Cleaning up the rust on the front lower front sill and cleaning up in general, Radiator is out (full of water so doesn't dry out and corode quiclly)
Problem is Alt light is full bright with battery connected and ignition off. Temp answer is disconnect the battery when the car is not in use.
Alternator is out of the car and can't find a short between the +and the wiring to the Alt globe on the dash. It still has the regulator conected and I'm wondering if this the prob?
Any help eould be appreciatted. Cheers
