I was going to say "two quick clutch dumps would have cleaned those semi's" but then remembered I was referring to B/T, which would be like trying to spin them with a 4k.
couldn't make it sorry Luke had a horrendous day Saturday which required Sunday to be spent in front of the TV.
But the good news is that the tennis ball is ready to have some high tech fitted!!
Edited by kickn5k
Nice commentary
Which video? If BT, blame my friend, if other cars, blame me! :laff:
As you may be able to tell from the launches, a 2A-C does not exactly light them up. Loads of grip, no torque to really do anything with it. :(
All good Stu, things happen, I will drag you & Godfrey along to one sooner or later! :P *cough bringthedatto cough*
Edited by carbonboy
More shots of Sundays antics, damn this is good fun! Except the early wake-ups on Sunday mornings, damn they suck!
post-5437-0-75812100-1372404635_thumb.jpg post-5437-0-28497200-1372404699_thumb.jpg
post-5437-0-09809800-1372404725_thumb.jpg post-5437-0-46422300-1372405648_thumb.jpg
Thoughts on where the rollaclub.com sticker should go? Top of windscreen or top of hatch glass? :hmm:
DIY valve lapping, an easy way to save some money at the machine-shop. Before on the right, after on the left.
All the valves are straight & with tolerances, so they're right to go back in. Still to double check the valve springs, but if they're also good, then that's $150 saved. Might splurge on getting the valves crack tested as well as the head in that case. :hmm:
More shots of Sundays antics, damn this is good fun! Except the early wake-ups on Sunday mornings, damn they suck.
Try driving two plus hours to get to most events :( and the sticker needs to be on the hatch.
Edited by coln72
Thankfully, I don't have to do that! For most of them at least. I'll need to test fit the louver & see if I can put the sticker where it's visible & doesn't foul on the wiper. Hadn't thought of that!
Still got the wiper! Get rid of that crap - too much weight ;)
ok - leave the wiper arm and remove the motor etc. Keep the stock look. You need to talk to Batch about sneeky (or not so sneeky) weight reductions ;)
Edited by coln72
The Bendigo round of the VMC is on the 20th of July, it also includes a JRace round, which is good to see as that appeared to take a little bit to get going. It'll be great to see you out there if you can make it. :)
The cylinder head destined for BT is now at the machine shop, after a lengthy chat with the guy we came up with a 'to-do' list. It reads along the lines of:
- Hot tanking (give it a proper clean)
- Hardness/Pressure/Crack/Vacuum testing (no evidence of overheating, just insurance & to see how good my valve lapping job is)
- Light skim of the block mating surface (no warpage, but some slight indentations from the head-gasket rings)
- Removal of factory casting/machining marks from intake/exhaust ports (those sharp edges, not a fan)
- Port match exhaust ports to manifold
That's it. Just the basics really, but that's all I need. Should have it back on Friday, currently doing my actual head in re-working out the intake manifold design. Optimal runner lengths, pressure waves... URGH. :(
From what I can tell, as long as the runners meet the head approximately horizontal rather than sloping down, the carburetors sit level & it all fits before hitting the clutch master/brake lines, it'll do! SamQ is kindly making an intake manifold flange to suit a bigport for me, a fellow TCCAV member has some tube/bends for me, I have a grinder & a welder, more times in the shed! :yes:
It sort of is, I read your thread on CAD programs & decided to give Google SketchUp a go. It's pretty easy to use once familiar with the controls & lets me see my dodgy pencil/paper drawings as a model of what I plan to make. Easy to tweak things as you go too, making it will be the real fun.
I'm a fan of this having this "spare time" I hear so much about, things can get done! Dropped off the crankshaft to another machine shop today, they're going to be cleaning up the main bearing & conrod big end journals for me & supplying bearings to suit. I balked at the quoted price at first, then realised it included the cost of said bearings & saves me having fart about. Done & done, see you in a few days!
In the meantime, the block is off the stand & on the bench. :dance:
