tavnam Posted March 24, 2014 Author Report Posted March 24, 2014 (edited) Bought this brand new for $200 the other day.. its a genuine Garrett turbo of a 6.2 litre John Deere tractor... Ill bolt it on n c what it does. can't hurt.... if it doesnt work ill buy a cheap ebay turbo Edited May 6, 2014 by tavnam Quote
tavnam Posted March 28, 2014 Author Report Posted March 28, 2014 picked up some more new additions to the workshop..... ive decided its alot easier to build anything when you have the right tools at hand, so ill be blowing some cash on a decent setup over the next few weeks... and ive also been doing a bit of tidy up work on my newest Ke70 aswell..... FULL SERVICE and interior tidy up n such... Really need to get around to buying sum S13 coil over's and making sum engine mounts..... not enough hours in the day.... Quote
tavnam Posted May 1, 2014 Author Report Posted May 1, 2014 Sooooo i just sold some parts and a corolla i picked up, so theres a bit more cash laying round to spend on the rolla so i bought a set of these S13 coilovers VVVVVV to go with my S13 power steering front end..... will also fabricate a rear end to include the rear Pair of s13 coilovers and r31 3:8 diff. Next on the list is the largest, thickest all alloy radiator i can get that will keep the 1uzfe as cool as possible..... with the turbo bolted on...... and ill purchase a BM44 brake booster and that will also get thrown in to the mix off parts..... Niassan S13 coilover details Fit for S13 Silva Japan Market 89-93 S13 180SX Japan Market 89-98 S13 Sileighty Japan Market 98 S13 200SX Europe/New Zealand Market 89-94 S13 240SX North America 89-90 Quantity 2 piece front + 2 pieces rear as shown Front Spring rate 8kg RearSpring rate 7kg Color Golden Damper 24 ways adjustable Damper Force Adjustable height YES Adjustable camber plate YES Warranty 1 year warranty Features * Adjustable ride height * Adjustable pre-load spring tension * 24 levels of adjustable damper -- This allows you the ability to perfectly dial in your coilovers system. You can enjoy confortable riding experience in all road conditions. * Pillow ball top mount -- this design helps combat noise while tuning. It also improves the steering feel and response * Most components are made from 6063 aluminum with T6 for increased hardness -- the advantages include excellent strength, and aluminum helps keep the weight down. * Hi Tensile performance spring - Under 600,000 times continuously test, the spring distortion is less than 0.04%. Plus, the special surface treatment is to improve the durability and performance. * All inserts come with fitted rubber boots to protect the damper and keep clean. * Improve your handling performance without sacrifice comfortable ride. * A fast and affordable way to easily upgrade your car's appearance. * Easy installation with right tools. * Ideal for any track, drift and fast road and can also be used for daily driving. Quote
tavnam Posted May 6, 2014 Author Report Posted May 6, 2014 Picked up these 2 turbo's and a Oil Filter Sandwich plate and oil cooler for free the other day. A friend of a friend is about to upgrade the turbo in their SR20DET powered datto bluebird so I'm going to end up with a matching pair of t28 2560's .80 A/R\'s that should safely provide 12 psi through a 04' WRX intercooler kit in never got around to fitting to my WRX... And if you've ever seen a WRX cooler kit you'll no that there easy to mount and come with heaps of piping...... soo looks like ill be saving for a computer, injectors and a decent fuel system now..... also going to have to do a built auto..... Still collecting parts and trying to keep costs to a minimum.. Quote
tavnam Posted May 8, 2014 Author Report Posted May 8, 2014 Fitted my S13 Front lower subframe and modified steering knuckle.... its currently a mash up of a standard ke70 top section with a s13 lower section... should definately do the job.... also picked up some basically free custom plates...... LEXUS TOYOTA "LEXTOY" aka SEXTOY coz yah missus loves it! Quote
