ke70-slider07 Posted February 4, 2013 Report Posted February 4, 2013 Alright guys easy little silly question. There is an oil line under where the left hand engine mount bolts to. Just wondering which way you guys have turned it as mine is coming out the top of the mount? Hopefully it clears everything as I'm putting it back together but most of you guys will have had the experience already so after any advice on this? Thanks in advance :-) Quote
rian Posted February 4, 2013 Report Posted February 4, 2013 (edited) My sandwich plate is in the original position (pressure release valve pointing down through the engine mount) but I turned the oil line around so it comes back out the top of the engine mount. I've also seen people rotate the sandwich plate like this so the pressure release valve doesn't sit in between the engine mount: Either way should be fine as long as the oil line doesn't rub on anything or come too close to the headers. You could always go to a braided line if you are worried about it. Edited February 5, 2013 by rian Quote
ke70-slider07 Posted February 4, 2013 Author Report Posted February 4, 2013 Hey turning the whole lot seems like an idea. Not really worried about it. Just kinda looks a little bit messy hanging out of the mount. I may just turn the whole plate i didnt think you could do that haha Quote
rian Posted February 4, 2013 Report Posted February 4, 2013 I'm pretty sure you need to modify the sandwich plate before you can turn it, but it wouldn't be hard to do. Quote
ke70-slider07 Posted February 5, 2013 Author Report Posted February 5, 2013 (edited) Ah all good i know a bit about changing metal as I'm a panel beater haha Edited February 5, 2013 by ke70-slider07 Quote
timbo Posted February 5, 2013 Report Posted February 5, 2013 My sandwich plate is in the original position (pressure release valve pointing down through the engine mount) but I turned the oil line around so it comes back out the top of the engine mount. I've also seen people rotate the sandwich plate like this so the pressure release valve doesn't sit in between the engine mount: Either way should be fine as long as the oil line doesn't rub on anything or come too close to the headers. You could always go to a braided line if you are worried about it. Haha, this is my photo/setup, works fine since the rebuild. Just cut off the tab where it bolts to the block. Quote
