Hi all I'm clearly new here and am in need of some help and/or advise.
I have just got myself a 1988 gtfx 1600 4age 5 speed manual.
now the car is overrated but the clutch feels like it's sticking and ridding. when i'm driving i can feel the clutch is not right when i'm driving. that and i can smell the clutch when i stop. what is the best cost effective options i have??????
any advise or help will be awesome.
thanks. D
From cheapest to most expensive:
- Adjust clutch pushrod under the dash
- Make sure you have enough clutch fluid, add more if needed
- Replace slave cylinder if it's faulty
- Replace/rebuild master cylinder if it's faulty
- Pull the engine and gearbox out and check/replace the clutch
- Buy a new car
But before you do any of this, I'd go out and buy a repair manual.
Thanks Rian for your advise.
I'll be trying everything I need to before I sell it. Just wouldn't get much for it here and is great on fuel (specially with a baby on the way). Money for a new car just isn't an option mainly because it's just not there. lol. But none the less thanks
lol- nice work Rian!
That suggests option 5, or maybe 6 if you're not mechanically minded!
I hate FWDs, and you're about to find out why... To remove the gearbox means pulling the driveshafts out, whch means pulling the suspension apart, then pulling the gear linkages out, then pulling the gearbox off to get to the clutch and replace it!
I've never done a FWD Corolla, but I expect they are like most FWDs.
Good luck
The smell isnt good...
run through rians list, but worst case you gotta change the clutch.
good oportuniuty to do a bit of maintenance though. Rear main seal, cv boots etc.
Edited by ke70dave
FWD aren't as bad as people think, not as easy as a hilux or landcruiser, but still easy none the less, toyotas at least. But that said I would still rather a landcruiser or hilux, hiace would have to be the easiest clutch to do, ever, haha. But everything else on them is stupid, haha.
