KE25_rolla Posted January 22, 2013 Report Posted January 22, 2013 Hey guys, I know this can be done, but has anyone on here actually fitted a 4Y crank to a 3T block? If so, was there much work involved in doing the conversion@? ie: what rods, pistons, were used. I assume it will need line boring? How much needed to be removed from the block to allow it to fit. What is the best bottom / top end combination to use? ie: 3TC/3TGTE bottom end, 2TGEU head? Any help and horspower figures would be appreciated. This will be n/a and not turbo'd. Quote
TRD ke70 Posted January 22, 2013 Report Posted January 22, 2013 Yip this has been done. Not real clear on how, The head to use is a 2tg, different intake ports to a 3tgte, apparently better for N/A engines. Have read of this, some good info. http://www.classic-celica.com/modules.php?name=Forums&file=viewtopic&t=93 Quote
KE25_rolla Posted January 23, 2013 Author Report Posted January 23, 2013 Thanks mate, seen that info floating around in various forms on the net. I think the 2tgeu head is the way to go from what I understand. 3t block is a must. BRD Racing quoted $5k USD for a 200hp engine with twin 45s. Bit of a bargain in my books as I'm sure I couldn't build one for that sort of money!! Quote
