tipsi Posted January 17, 2013 Report Posted January 17, 2013 What diff is the best I was thinking hilux, vl turbo or r31 With a powerglide wondering what to with the front leaf spring Quote
Tally Posted January 17, 2013 Report Posted January 17, 2013 Hilux can't go wrong. What happened to the 20b ke25? Quote
altezzaclub Posted January 17, 2013 Report Posted January 17, 2013 The R31s always whine, same Borg-Warner as the KE. Surely the Hilux lasts longer? What is wrong with the front spring?? They have been used on a lot of cars, from Corvettes to Datsun utes, an they have this neat property- if you have 2 mounts that the spring is free to pivot in rather than a single central mount, you can control the cars anti-roll by adjusting the distance between those 2 mounts. I'd look upon it as a great challenge to modify the transverse setup to handle like you want it to. Quote
ke70dave Posted January 17, 2013 Report Posted January 17, 2013 (edited) My borg warner was silent after i replaced the worn bearings. (KE) I suspect most R31's have worn bearings! btw a hilux diff is MASSIVE. and a ke10 is tiny. The tyres you choose to use, along with how you intend on using the car will dictate your diff choice. 185 wide street tyres and driven on windy roads, or 295 slicks and driven on the quarter mile? Edited January 17, 2013 by ke70dave Quote
19914afc Posted January 17, 2013 Report Posted January 17, 2013 Can get real early hilux diff that should be good for a 10. Quote
tipsi Posted January 17, 2013 Author Report Posted January 17, 2013 Nah tally that's my brother his still going for that set up I am just wanting a tough street car Quote
altezzaclub Posted January 17, 2013 Report Posted January 17, 2013 Dave, which bearings were noisy, diff or wheel? What did it cost to do? Those R31 diffs are a giveaway at the wreckers. Quote
tipsi Posted January 17, 2013 Author Report Posted January 17, 2013 I was thinking of changing the leaf springs to white line sway bar Quote
LittleRedSpirit Posted January 17, 2013 Report Posted January 17, 2013 That statement doesn't make sense to me. Explain? Quote
oh what a nissan feeling! Posted January 17, 2013 Report Posted January 17, 2013 did someone say the r31 has the same diff as a ke corolla? lol. surely i read that wrong. vl turbo diff is the same as an r31, bw78. the 4.1 ratio that is found in the pintara's for these diffs are known to be noisy, none of the other ratios are have any problems. If the car is turbo you wont want 4.1's anyway, also if the car is turbo and 3rz you wont get it registered legally. Quote
altezzaclub Posted January 17, 2013 Report Posted January 17, 2013 the 4.1 ratio that is found in the pintara's for these diffs are known to be noisy, none of the other ratios are have any problems. that's interesting. I told the wrecker my R31 Pintara diff was noisy and how much did he want for a Skyline one, and he said he wouldn't sell me one as they would all be noisy.. So I thought the whole production line was crap. Quote
altezzaclub Posted January 18, 2013 Report Posted January 18, 2013 The front leaf spring haha Why do people change them?? Don't they understand them, or is there really something inherently better in LCAs and MacPhersons apart from being cheaper to manufacture? The spring acts as a sway bar & with a little work you cxan adjust its stiffness, there is a lower A-arm to hold the wheel fore and aft in castor, and the strut gives camber control. ..or do I have the wrong photo here?? You can alter spring rates & anti-roll stiffness, although getting -ve camber might be exciting. I'd never played with one, but I'll take a look under Rob's when I go around there next. Quote
