Taz_Rx Posted January 6, 2013 Report Posted January 6, 2013 Just find a cheap but half decent aftermarket ecu for $200-300.... Then you'll actually hasn't tunability! Get a wolf 3d v4 and ill send you a map! Quote
starky Posted January 7, 2013 Author Report Posted January 7, 2013 Just find a cheap but half decent aftermarket ecu for $200-300.... Then you'll actually hasn't tunability! Get a wolf 3d v4 and ill send you a map! you already have a map for the 7k efi? what were your dyno figures? Quote
Taz_Rx Posted January 7, 2013 Report Posted January 7, 2013 100rwkw on 10psi a few years ago. Road tuned it a couple of months ago, i'd guess about 120-130 now. Click "tar"in my signature. Quote
starky Posted January 8, 2013 Author Report Posted January 8, 2013 do any other toyota engines bolt up in place of the k series? like y series? Quote
starky Posted January 8, 2013 Author Report Posted January 8, 2013 does any one know if a 5k manifold will bolt up to a 7k-e head? the reason i ask is because i don't have the time to bugger around with the injection just yet. plan is to buy the donor engine throw it in with the 5k manifolds (if this is possible) and then when i have more fit the injection Quote
Taz_Rx Posted January 9, 2013 Report Posted January 9, 2013 Sure will. Be aware that both the inlet and exhaust ports will be bigger than the manifold runners though. As I said earlier 7kc are the same size. Quote
