hi, I'm from Indonesia ...
I am currently making convert to the corolla 4 door to 2 door,
pillar in the middle is my cut and slide, this time I will do more long front door, and I hope my friends can help me find inspiration in this project..
sorry my english langguage too bad... :)
its the image, and i will update after i working...
Can you get the long doors and the rear glass for it locally?
You could pump the sills full of expanding foam to stiffen them now you have moved the B pillar. That would help stop the body flexing.
hufttt.. iam sorry...i can't translate you word.... :(
so i can't answer you question..
It certinaly stiffens panels up, but I don't know which are water repellent and which aren't. I used to use the 2-pot mix, which set off chemically with one bottle of hardner and one bottle of resin joined at the gun, but these one-shot aerosols might be quite different in water properties.
Its great for forming 3D shapes, such as ribs under a f'glass bonnet or guard. Ooze it into a channel of cardboard then glass over it again.
