camorinta Posted November 27, 2012 Report Posted November 27, 2012 so i bought a whiteline swaybar for my ke17.. annd it fouls on my brake calipers so i had it shortened.. as in cut a chunk out of the middle n then re-welded it. now I'm getting mixed reactions..some say it needs to be heat treat it, lost its strength etc.. and some are saying it will be okay to chuck it on... opinions.. ? think ill chuck it tomorrow, see how we go? cheers amar Quote
philbey Posted November 28, 2012 Report Posted November 28, 2012 How did you weld it? Did you put a full chamfer on the ends and layer multiple welds, or did you just whack a single weld on it? Quote
camorinta Posted November 28, 2012 Author Report Posted November 28, 2012 Yes it chamfered, not too much but yeah after cutting it we cleaned it up and layered the welds. I think it should be strong enought to hold but will it loose its 'spring'? Quote
philbey Posted November 29, 2012 Report Posted November 29, 2012 It wont lose it's spring. What you've done is reduced the total amount of 'twist' you can apply to the swaybar. In reality, probably not by a whole lot, but it'd be straightforward to calculate. All a bit to scientific though. How good were your welds, they would be my main concern. Poor welds with pinholes or porosity would have me a little concerned, they could create a stress concentrator and a fatigue failure might happen. It could be a long time down the track as well. Quote
ScottKE1X Posted November 29, 2012 Report Posted November 29, 2012 If you do chuck it on, keep us posted. Then tell Whiteline to make them all shorter to start with for the rest of us ;) Quote
ke70dave Posted November 29, 2012 Report Posted November 29, 2012 (edited) I would be planning for a worst case scenario on that weld....epic amounts of fatigue loading on a swaw bar. Perhaps an alloy under tray on the car,So if that weld breaks you might have a chance of not pole vaulting your car off the road :P Edited November 29, 2012 by ke70dave Quote
camorinta Posted November 29, 2012 Author Report Posted November 29, 2012 haha ferk, don't want to be pole vaulting anywhere! :P Gave it a crack yesterday, quit half way coz of the temperature haha but noticed that the bar will probably foul on the body now. Ill try n upload a photo soon.. its getting too 'Ugly' now.. not sure if ill be doing it.. :S ... If the bar is under such loading how can there be those adjustable one's? Like with that thread and bold set up in the middle of it.. Wouldnt that give way as well? Cheers. Ill take some photos today. Quote
ke70dave Posted November 29, 2012 Report Posted November 29, 2012 Which adjustable ones be this? Quote
camorinta Posted December 1, 2012 Author Report Posted December 1, 2012 One of the boys has it on his ke70.. well didnt have a close look... looked like a sway bar :P the pic is below.. Now for my sway bar. I will go check one set up that a bloke said worked out n then update this.. haha don't want to even post a picture of 'what was planned' haha .. Quote
ke70dave Posted December 1, 2012 Report Posted December 1, 2012 that aint no sway bar. that some brace thing they put between the castor arms. http://www.ultraracingaustralia.com.au/index.php?categoryid=15&p2_articleid=32 "front lower brace" in the above link. Quote
camorinta Posted December 1, 2012 Author Report Posted December 1, 2012 had a feeling that was coming.. haha that's why i wrote didn't have a close look :P Thanks Quote
TOMMYS Ke 11 Posted December 1, 2012 Report Posted December 1, 2012 You were on to it Dave.We are having the same problem with Thomas swaybar but hopfuly will get it sorted tomorow i will keep you all posted on the results on Thomas thread all the best with yours.We can not blame Whiteline for this problem as they would work fine with stadard drum brakes we just need to sort this out and maybe let Whiteline what they could possibly do to fit disc brake conversions. Cheers:-Stuart Quote
TOMMYS Ke 11 Posted December 2, 2012 Report Posted December 2, 2012 I think i have fixed the problem i have put the details up on Thomas ride thread TOMMYS KE11 have a look and tell me what you think. Cheers:-Stuart. Quote
camorinta Posted December 2, 2012 Author Report Posted December 2, 2012 kimda regret cutting mine up now :S haha waste of cash.. :S well tell me how it works out.. seems to clear fine :) nice sight :P haha .. what brakes are those? cheers for the updates. Quote
