weird problem
when i indicate left the blinker stays on...
not only does it stay on the parker turns on not the blinker at front
the side and rear blinkers just stay on
right side works fine
i may have disconested a few wires when doing the conversion but all plugs to indicators are correct
and ideas guys?
Thanks for quick reply...
You seem confident there so ill have a look.
Where exactly is the earth for the front indicators on the loom?
Would you know what colour wires.
Also
Sines the conversion I don't get reds on dash.only indicator arrows fuel and water temp work but nothing else...any ideas?
Main thing ATM is the blinkers
red lights are normally ignition driven, check your fuses, there shouldn't be that many..
I had a similar problem with some early ke's helping people out over the years. is it a 2 wire or 3 wire combo (park/indicator) light?
2 wires come from side indicator.
and 2 wires come from the indicator parker combo on front apron.
so I'm guessing side indicator has a earth but the front doesn't.
any idea what colour wires is the earth on the loom on passenger side for blinkers to check it?
running out of ideas and want to drive it but don't like driving with no blinkers.
was also thinking flasher unit but that wouldn't cause the parker to stay on when the left hand blinkers stay on.
