It doesn't learn that much.
Your answer is that you don't need to do this now until you can afford it.
All you will get is grief, and you will hate the car.
Apprentices should stick to stock motors and chassis. I know I couldn't have done a modified car with a $6 and hour wage when I was an apprentice.
Just do a lot of research and save what you can over the next couple of years and you should be able to do it. It may well be easier to do a 20v conversion if you want to continue to use a stock ecu.
