Hi,
I want to clean up and paint the steel rims on my Rolla.
I need to do it on a shoestring.
So I am going to remove the rust and old paint using a cup brush on a grinder.
I just need to know how to prepare the rim to get the paint to stick. I will use spray cans,
After I use the wire brush Do I need to scuff up the steel? Maybe with those scour pads?
What is a good automotive primer in a spray can will do the job?
And what type of top coat is best?
Ted
Sand them as well. You can't get into all the grooves with a wirebrush, and the wirebrush with leave scratches if you don't sand it.
We sprayed a friends on his ke30 with 'Squirts' was like $9 a can at mitre 10. Nearly 2 years ago and still looks good and chip free
