4agzeturcel Posted September 17, 2012 Report Posted September 17, 2012 planning on doing a 4agze engine conversion can i just remove the supercharger and put my turbo setup on I'm using a steam pipe manifold and a rb20 turbo not after any huge power will the 4agze ecu and injectors be ok on 10 psi? is there any problems doing this? Quote
kickn5k Posted September 18, 2012 Report Posted September 18, 2012 I think you'll need a 4age inlet manifold too. I'm helping a mate do a 4agze conversion into a ae82 at the moment. It runs the Nevo larger pulley giving it 12psi and still runs the std ecu and injectors. But I'd still run it up on a dyno to see what it's doing. Quote
4agzeturcel Posted September 18, 2012 Author Report Posted September 18, 2012 ok so i just need to find a 4age rwd inlet manifold then? does all the sensors and throttle body off the gze bolt up to it? Quote
4agzeturcel Posted September 18, 2012 Author Report Posted September 18, 2012 just looking at the factory power for the later gze map sensor version and there only 120kw roughley what will one make with a turbo and the stock ecu and injectors near maxxed out because if its not much i may aswell just get a blacktop 20v Quote
kickn5k Posted September 18, 2012 Report Posted September 18, 2012 ok so i just need to find a 4age rwd inlet manifold then? does all the sensors and throttle body off the gze bolt up to it? Or get a fwd one, cut both ends off and get them welded on the other end. Not sure about tps and sensors sorry. Quote
