The front left has negative camber for some reason. It has KE20? struts with 55 disc brakes or something. Gotta figure out whats going on.
On the drive home the clutch cable popped off the pedal, that was interesting. Lucky I was pulling in to a servo. Zip tie should temporarily fix that.
It'll get a mini service tomorrow, gotta figure a way to strap in the kiddie seat in the rear. Some speakers in the front, hook up the aerial to the stereo.
I really don't want to spend too much, its meant to be a daily.
Lower, steelies, done.
Anyone have any info on the front end please chip in!
  On 9/8/2012 at 9:58 AM, NISROLA said:
Rip the tint off, venetians on the sides, white walls with hubcaps,
And a cage haha
Great minds think alike. can't imagine what venetians would cost for this though :o
Get some old blinds from somewhere, tipshop etc cost 5 bucks, cut to size with tinsnips.
Positive or negative camber? Ke20 struts add positive camber
Ke10 struts are better. The camber etc is much nicer. Easiest way to tell if it's running ke10 struts is stick your head under the front and see how many bolts hole the steering arm to the strut.
Ke10 has 3 bolts and a triangle strut base, ke20 etc have only 2 bolts.
Edited by Jono.C
reed i have 5 mazda 626 rims 13 x 5.5 from memory with brand new, never used 175/50 rubber if you need
and bloody great score mate..!
Edited by nerfbat
Have a look for mix and match struts or bent stuff, Never seen that issue before..
Mind you the strut tops now they're old are very easy to snap or bend
Will have to get under and have a good look.
  On 9/8/2012 at 10:28 AM, Willis said:
So I guess there's only one question left to answer then Reed....
Does it skid good?
Yes, it drifts like a Silvia
  On 9/8/2012 at 10:33 AM, Stenzel said:
If he skids it, I told him I know where he lives and I will punch him in the face :thumbsup: fOIwE.gif
Edited by B.L.Z.BUB
Like a Silvia? You mean with like, coilovers n that yeah? Must be a pig.
I don't know where he lives but I'll just tag along with you. I'll hold him while you punch him.
  On 9/8/2012 at 10:41 AM, Jono.C said:
Bet it'd totes do a mean single pegga lolz.
Those single pegger things are seriously underrated. Don't know why people even bother with lockers and LSD's hey.
