  • Replies 48
Looks very much like a Denso to me. In a '55 right? Bosch units don't have the knob on them to adjust timing depending on fuel grade (clear cover over it).
Edited by snot35
Shows you on the website
But it comes with
The pickup/module which is the little little red box and 2 wires, this is mounted on a base plate that simply bolts to the dizzy where ur points would
And it also has a black ring, this slips over the dizzy cam (the part the the point runs on) this is the magnet that the pickup senses
It also seems very important according to the website and the instructions they sent that ur coil must the correct resistance otherwise ur module/pickup will fail
I used a hotspark module designed for a land rover.
i had to drill and "cut 'n' shut" the mounting plate for it and modify the trigger wheel that goes over the breaker points cam with a bit of quick bond.
i can post some pics up if anyone is interested.
Pictures!
also as you can see I've locked the vacuum advance...
this is to compensate the fact my 4k corolla is a race can and always at full throttle...
and the positioning of the module wouldn't allow the room.
Edited by GREESR
