Not sure what oil to run in the freshly built formula atlantic spec 3k race engine of my old mans, is just being run in atm, from memory its 12.5:1 comp ratio, has big cam, 45mm webers etc etc a long list of work done, is worked to its limit.
Would like some advice on oil from people who have owned heavily modified K motors as i am more familiar with turbo import engines, i want to make sure it is the most ideal oil for it as the bottom end rebuild on this was far from cheap.
discuss please :) cheers
Ahhhh, This is that old hillclimb upright 3k ke10?? Good to hear it's still around!
Yeah thats the one still about, we just don't get it out much with everything else going on
Thanks for the input, will continue to research
Good to hear!!
Could you throw me a pm or something perhaps if you take it out to any events or something? I'd be insanely keen for a look!
