madrolla68 Posted February 2, 2006 Report Posted February 2, 2006 Guy's another question,will the 7K fit in a KE10 due to the extra depth of the sump for the extra stroke and are there any other issues . ive got another KE10 auto that i might do something with. Matt Quote
Felix Posted February 2, 2006 Report Posted February 2, 2006 (edited) i know of a guy who put one in his ke17. from what i remember him telling me, he had to cut and shut the sump to clear the xmember. apparently the sump is wider than a normal 5k sump, which makes sense to accomodate the extra stroke. apart from that it was just a bolt in. i never went for a run in it, but a friend did.... effortless power. Edited February 2, 2006 by Felix Quote
madrolla68 Posted February 2, 2006 Author Report Posted February 2, 2006 Torque on tap. Good to see some people looking into the 7K's... Plenty of potential Yeah i measured one up a while back and figured i would have to cut something,wonder how they would rev with the extra stroke over the 5K. Quote
Fayt Posted February 2, 2006 Report Posted February 2, 2006 (edited) mate of mine has a 7k in a ke20, it uses the same engine mounts as a 5k he runs and owns his very own Japanese modification place and he did it himself, so he knows what he's talking about :P he didnt have any problems swaping the engines over, but this was a ke20, not a ke10, if that even matters Edited February 2, 2006 by Fayt Quote
Teddy Posted February 3, 2006 Report Posted February 3, 2006 people say that 7ks wont rev. Yes, from stock, they are not a very rev'y motor. But with some modifications, i would put a nice chunk of money on there potential. Up the torque :P Quote
madrolla68 Posted February 3, 2006 Author Report Posted February 3, 2006 people say that 7ks wont rev. Yes, from stock, they are not a very rev'y motor. But with some modifications, i would put a nice chunk of money on there potential. Up the torque :P Yeah its the whole "undersquare" thing that makes them not rev too good. I will look into it and see what the deal is,does anybody know if the cams are the same,manifold bolt pattern,bellhousing bolt pattern????????? Quote
TRD ke70 Posted February 3, 2006 Report Posted February 3, 2006 heard the same thing about the 5k's when they came out, that it wasn't a rev,ing engine. seen many a 5k hit 8000+rpm no problem. i'd expect a 7k with a change of cam, solid lifters,head work, decent carbs, etc to see 8000rpm. reliability shouldn't be a problem, as they are a commercial engine and there toyota. Quote
SLOTH Snr Posted February 10, 2006 Report Posted February 10, 2006 You have to change the sump a 3k one fits you just have to modify the oil pick up. Due to stud patterns only a 7k head will fit the block. All kmotors fit k bell housings. 7K starter motor is smaller in the body We will know just how a 7k revs in a couple of weeks. We need a 7k manifold gasket. Got laughed at when i rang around a 7what they all said. Why would you want to over rev a 7k Max tourque is about 4250 Max horsepower low 6000 Quote
