Whatsausername? Posted July 31, 2012 Report Posted July 31, 2012 Okay, So basic plans are... I have the stock Ke70 crossmember, Lca's, Rack, Tie rod ends, Sway bar etc etc....BUT I am using/want to use S13 knuckles/brakes....All is good and well except the hole on the knuckle is a mm or 2 too big compared to the KE70's ball joint...Any way to fix this? Cheers, Nathan. Quote
Whatsausername? Posted August 1, 2012 Author Report Posted August 1, 2012 10mm longer than KE lca's or S13 lca's? Quote
Jono.C Posted August 1, 2012 Report Posted August 1, 2012 10mm longer than ke70 lca's. When you put them it leaves a good, normal amount of track amount unlike s13 lca's which add a metric ʞ©$ɟton per side.. Quote
Whatsausername? Posted August 5, 2012 Author Report Posted August 5, 2012 Awesome, Cheers dude, I really appreciate it! Quote
