WhatTHE!!! Posted January 30, 2006 Report Posted January 30, 2006 (edited) car make: Toyota TE72 1980 engine conversion: 4AGE mod: Toda cams 288/272, side draft Weber 45DCOE, TRD flywheel 3.7kg, 1G starter motor, Ultra pulg cables, Angle Big Coil, NGK Japan pulgs, Thrust 4-1 exhaust extractor, T50 TRD close ratio gearbox, 2 way LSD, TRD front and rear suspension, Tom's steering wheel, full roll cage, KUMI brake pads, TRD clutch, enlarge master brake pump, engine oil cooler.... a lot more. before paint big coil 45DCOE KUMI brake pads more picture in my MSN blog. DIY gas padel DIY seat mounting + harness Drift accident DIY vented hood DIY bac. relocate spacer my 4AGE carb Edited January 30, 2006 by WhatTHE!!! Quote
Jason Posted January 30, 2006 Report Posted January 30, 2006 you sure do like pop rivits don't you :y: Quote
anastasios Posted January 31, 2006 Report Posted January 31, 2006 awsome car man awsome I'm doing the same thing into a ke70 atm is yours big port or small port how did tuning the carbs go? Quote
WhatTHE!!! Posted February 1, 2006 Author Report Posted February 1, 2006 Jason said: you sure do like pop rivits don't you :y: well.... this is the cheapest, simple, user-friendly method.... great for DIY..... anastasios said: awsome car man awsome I'm doing the same thing into a ke70 atm is yours big port or small port how did tuning the carbs go? well.... alll about settings.... you might experience your carb runing rich in fuel.. as a result, you need better firing.... get a big coil (size does metters).... good plugs... 4A engines are good with NGK Japan.... my engine was tune in Japan... so i don have much prob. (was used for N2 race back then) Quote
Ke50 Posted February 2, 2006 Report Posted February 2, 2006 may i ask if that car uses leaf springs or coils in the rear? just curious Quote
born_rolla Posted February 3, 2006 Report Posted February 3, 2006 thats a drift bitch if i ever saw one my mate living with me at the moment has one them the TE72's are great cars. another strong toyota made car strong 3t's if treadted right good diff's same lay out as a 86 and KE. pitty only the fisrt series came out with no sway bar mounts that sucks balls..... any ways mad ride much respect for the effort u have put in to it.. Dai Quote
Ke50 Posted February 3, 2006 Report Posted February 3, 2006 Jason said: coils damn! i wanted to you say leaves! then i would feel better about drifting my car lol :P Quote
