Ok so the 4AGE I bought had no exhaust manifold and no bolts or nuts for it.
So here is the dilemma I bought some high tensile M10 x 1.25 35mm (or 45mm can't remember of the top of my head I can check though).
Will those do the job?
The nuts thread on fine.
But the bolts are quite firm. ei can barely be twisted by hand.
I am shit scared of snapping them in the block! Is their something I can do to make it a bit easier/safer?
Many thanks!
Edited by It's_AUDM_Yo
You should never insert bolts into an aluminium head in this scenario, get a 10x1.25 tap and give them a clean out and then if you can, get some studs.
  • Upvote 3
Cheers Trev
Ok I'll give it a clean with the tap. I thought you ran bolts in these ones as the 3 studs up the top look un-removably.
Do you reckon I will be able to get them through Toyota? And would you just put some Loctite on the new studs?
Last one do you reckon the the high tensile nuts from super-shit will do the job?
  On 7/17/2012 at 11:38 AM, ke70dave said:
spring washers are the go on exhausts.
This, or you can get actual flanged exhaust nuts but it depends where you go.
Mine gets hot enough to reset the metal. Every time I've tried them they've been absolutely useless. I'm sure I've still got a few flattened spring washers around here somewhere.
Bloody awesome guys!
What are the cast iron washers for? If the stud isn't the correct length?
I'll go to Toyota/Nissan tomorrow
Grab some spring washers and nuts as well at some point.
If anyone happend to know the Torque setting that would be sick!
They retain the manifold and stay in one piece with heat.
