When I ran at the saleyards, many moons ago, it was really slippery. Grabbed the handbrake for the first time and looped it :paperbag: Learnt to be really careful after that. The only motorkhana I have ever hit third gear on. The other competitors were not happy with me when a shit load of dried mud fell off the bottom of my car just before the finish garage. Think I placed outright that day, but never confirmed it.
  On 4/9/2013 at 8:30 AM, azza91 said:
great to see you back out having a blast mate.
Thanks mate :)
yeah i pretty much did the same thing :P yeah dw i piss people off all the time cause i do so well in a shit box rolla :P I just go out have fun and try my hardest to do well ;)
See ya
Jimi
Ok so its been a bit dead around here :/ Sorry everyone!!!
Been busy doing racing like normal :P Just motorkhanas and autocross's like always hahahaha But been busy as on the side with other stuff!!! Plus been to some rallys and VCAS rounds!
I also had my clubs presentation, i did well :P I got Club and Motorkhana champion for 2012 season :D All the hard work i put in payed off :P So proud of myself and the mighty Trolla!!! I also smashed the club record for most points to win the club champion or something :P Not bad for a rolla ;)
Anyway back to the trolla :P I did some work on her the other week and added a new switch panel to make the dash tidy!!! Now all my switches are in one place and they light up so i can see if it blows a fuse easy!!
This is what i put in.....
Will make it a breeze!!!!! I do have some left over wires I'm not sure where they go so have just tapped them up and put under the dash till i can figure out where to put them :P Also pulled the carbie and manifold of so i can put the WEBBERS on !!!!! :D So now begins alot of work to get it all running and sorted, i have a elec pump and all the stuff just need to wire up and mount everything so i can get it tunned!!!
So when i get some time in between rallys and other stuff i will get this all sorted out so i can go do more events :D
Hope to add pics and updates soon!!!
See ya
Jimi
Thought i should take some pics with the car and the 2012 season trophys :P
They call me Trophy Hunter....
See ya
Jimi
  • 3 months later...
Ok so its been ages since ive done an update!!!! Alot has happend...
So i have put the elec fuel pump and a marine fuel filter in the rear, Installed the hydro handbrake and plumbed up the brakes lines. All working good :D
Also got around to installing the webbers!! Took me awhile to get them rebuilt but got it done! Got it all mounted and installed to get it tunned :P So Saturday i took it around to my local carbie man and he helped me out get the old girl tunned!!
It went great ! Took abit of changing jets etc but once we sorted it out it was done :D Unfortunately near the end the exhaust had a leak and bad! :bash: Was def coming from the gasket :/ All good it was tunned and set! Just need to fix the gasket :P
So Sunday i pulled the webbers of and had a look at the gasket .....
yeah its def that :P So after a ask and look on rc i found the part number for a one peice gasket, went and got some on order. Then moved the engine loom so it didnt get in the way of the webbers and socks, also made some little brackets to hold the brake line down!
So now I'm waiting for the gaskets to arive then ill get back into it :P Also might check the tappets again lol
Besides the trolla i have been doing some events but not many as i don't have a car to compete in hahah So i borrowed my sisters excel a few times and even owned a excel at one stage. Did manage to win a motorkhana in my sisters car the other week :P
Hope to add some pics up later
See ya
Jimi
Ok so i got the gasket sorted and fixed before the Winton 6 hour, Did a few other jobs and got some new wheels and tyres. Also added some Speedhunters tow hooks i got to bling her up abit :P
So the weekend went great!!! Had a few dramas on sat but was just the socks, put a new set of plugs in before the weekend and by the end of the first session they where fouled :/ After talking to someone it was down to the socks as there squashed together so restricting the air flow, so wipped them off for sunday. The only other prob was a slight oil leak, after a look found to be coming from the spark plug buckets. So got a hammer and gentle folded edges and ends in to clamp better. This worked but still leaks a little but will fix later as its fine for now.
So came race day and the car ran awesome!!! Sounded so much better with open webbers :P Revved so much better to, was able to control the throttle much better through the corners.
When i went out for one stint the car got a we bit hot for my liking so i backed off abit and let it cool down, didnt help that it was a Hot day and track :/ So was pulled in and after a check just put it down to that.
So once i was ok with that and pulled the front number plate off to help get some more air in i went out for the last 5 mins to bring the team home over the line :) I just went out and gave it my all managed to have a great fight with an alfa and passed it!!!
All in all it was a great weekend and i didnt have any major issues :P
When i got home and went to put car out the back i started her up...... BRAA BRAAA SHIT!!!! She blew another gasket!!!
This was not good as i was doing an event that weekend!! So i pulled the spare out and went to work to figure out how to fix it properly!
After a drive around to some exhaust shops i was told to get an arc rod and clean the spur stuff off, then cut to length and put behind the washer on the side that is diff height to the other manifold. I did this and it worked! All the manifolds bolted up good and flush now!!! Arrrr....
So the car was all sorted for bagshot rallysprint :)
So came race day :P Got some rally tyres this time and put the socks on, was not sure how it would go as it was my first event on dirt.
So when it was my turn i went out and gave it a crack, it revved fine and wasnt like it was when driving down the street. So after 6 runs i put her on the trailer.
The day went great and no problems, a few big knocks over some bad bits as it was rough hahaha even got air on jumps ;) But when i went to disconnect the batt i looked and found the strut top to be broken :o Woops! So i was very lucky hahahah also broke a window winder but no biggy :P Also chucked my big speedhunters sticker on ;)
So now ive just fixed the strut top after going into the shed to find another one, dad said he has never seen a strut top break like this on a rolla!! Must have been rough!!!
Got heaps of vids to come :P Updates will keep coming!!
See ya
Jimi
Thanks to John and Paul for the pics!!!!
Awesome! The rubber on these cars is getting pretty old these days, I'm not totally surprised. Was the bearing still able to turn or was it full of crud? That could also explain things!
  On 10/29/2013 at 10:09 AM, sebsta said:
Forgot the most important pic !!!!
We got air !!!!!!!!
Oh yeah forgot that :P
yeah i know :P yeah think so might check but still not normal to happen really hahah oh well race car i guess
See ya
Jimi
So i did a motorkhana on the weekend :) was last one for the geelong championship, was first time with new motor and hydro so was excited to try it out!!! Went great! Did have some driver eras but other then that did great! Had a few people come up to me after some runs saying it was running on 3 cylinders :/ So tried to fix it but still there. After some chat with a few friends and that its got to be the sock filters!! So just measured the distance between webbers face and strut tower and have found a filter box that will fit :D
So will order this soon and get it all sorted and hopfully fix all my problems!!! Then get onto all the other jobs i need to do hahahha
Also 17th of nov ive been asked to do a special event Ekiden Day - 2013 :) Toyota Motor Corporation is holding their annual family day at the Altona plant this year on Sunday November 17th & has invited TCCAV to bring our cars for a show & shine &run a motorkhana in their front car-park. Last years event was fantastic & our members enjoyed factory tours of the plant on mini-buses, which was a heap of fun. To give you an idea, check out how much fun Luke (oh wait, that's me!) had revving a $660,000 supercar at the event in 2012 by clicking here. This years event activities have been kept well under wraps, so we are expecting something exciting & different from our manufacturer.
Details are;
Date - Sunday 17th November.
Location - Toyota Altona Plant, Grieve Parade, Altona.
Time - Meeting from 8.30am. Enter Toyota as a group at 9.00am. For a Google Maps link, please click here .
Meeting point - Westgate Indoor Sports. Corner of Grieve Parade & Dohertys Road, Altona.
Entry Cost - Free! Just bring some money for lunch.
For more info, or if you have any questions, you can contact Frank Ferrantino at: frankandbec@hotmail.com .
Hope to see a few rc members there!!! Would be great to meet more people :P
See ya
Jimi
Oh and i got 2nd outright at the motorkhana :P Not bad on 3 cylinders ;)
So another update...
Its time to fix some problems with the car, fuel line needs to be bigger and clean tank. Fix all the wiring loom and make it work and look neat. Sounds simple...
Once i started to remove the webbers, found bodys to be damaged and will need to be welded and re-drilled to fix
Then got the wiring loom from dash and engine out, found most of the headlight wire to be burnt out :/ So now will re-wire and fix this all!
Then got most fuel out of tank, removed tank and found rust hole around filler neck :/ So now will have to fix this and also put bigger pick up line
Things look grim atm but hopefully things pick up for me
See ya
Jimi
yeah thats it!! Doesnt help when theres an event on feb 2nd i want to do :/ Might have to borrow dads rolla when thats fixed hahahah
Heres a pic of the hole :/
Dad suggested i cut one out of another car to get the right curve and shape etc....
See ya
Jimi
