930LLO Posted June 23, 2012 Report Posted June 23, 2012 (edited) Hey just wondering if any of the KYB shockies compensate for a larger tyre? Otherwise ill be getting the angle grinder out and making these tyres fit. Currently got stock shockies and springs, had 195/60's on the front so I thought they would fit on the back. :( Cheers Edited June 23, 2012 by 930LLO Quote
B.L.Z.BUB Posted June 23, 2012 Report Posted June 23, 2012 If they are only just rubbing get 5mm spacer? probably safer than grinding your tyres. Quote
B.L.Z.BUB Posted June 23, 2012 Report Posted June 23, 2012 Ahh my bad, by saying shocks I thought they were rubbing on the inside 8/ Quote
19914afc Posted June 23, 2012 Report Posted June 23, 2012 ae92 would be better with a 50/55 profile in 195 R15. Actually not sure how much difference it would make. Quote
Hiro Protagonist Posted July 2, 2012 Report Posted July 2, 2012 (edited) Tyres are too tall mate! ^THIS Stock size would have been something like 175/65/14 or 185/60/14, to keep the same diameter in a 195 15" you'd need to go to a 195/50/15. Speedo is going to be off ~7% too with those fronts (would be off 10% with 195/65/15), which is illegal (as you are reading way under what you are actually doing) EDIT: unless of course this is a track car, but it doesn't sound like it. Edited July 2, 2012 by Hiro Protagonist Quote
Boosted Posted July 11, 2012 Report Posted July 11, 2012 If you used the steel wheels from a later corolla, or 15" mags from a later corolla, the offset is different by 5mm, meaning 195's will rub on the shock shaft (they do actually clear, but by less than 3mm and tyre flex will result in rubber marks on the shock). As mentioned as well, 65 series are also too tall and will foul with the spring seat. My old shocks had the spring platform 'massaged' with a hammer to provide some clearance (I do not recommend this) I've got 195/50R15's on the TTG Rolla with 15mm spacers (dedicated motorsport car), they give plenty of clearance from the shock strut and still aren't close to the lip on the guard. AE's are always a PITA when trying to fit bigger wheels to the rear, you've got truck loads of room up front by comparison. Quote
derrickgeneric Posted July 19, 2012 Report Posted July 19, 2012 i agree with them that 60 series tires on 15s are too tall. 50 or 55 series would be perfect, ive got 55 on mine on a lowered stance, no rubbing issue even with 3 passengers inside. Quote
