Hey rollaclubbers. I have acquired an auto ke20, but I want to convert to manual at some stage. I have a ke70 manual gearbox and xmember if I can use them? Or is it a lot easier just sourcing ke20 manual parts, and the same for pedal box? Cheers in advance
Edited by madKE35coupe
hey man the ke70 box has a different shifter position and the auto tail shafts are different , and i might have a petel box and ive got 4 speeds every were atm if your keen 0401060737
You can use that gearbox but you'll have to cut extra room for the shifter being further back. Pretty sure.you can use the auto cross member you just have to re drill holes to suit ke70 gearbox mount. Easy enough. Pedal box will be required from a ke20.
