Standard fuel tanks are baffled to reduce sloshing around. My after market fuel cell is foam filled.
Are those cells E85 compliant taz?
Hmm, something to keep in mind! Never thought of that before.
Yeah I asked about one that looked the same as yours for my car. Was told that the majority of the new fuel cells were now made with baffling in either a steel or aluminum(coated internally) so they were compliant with a wider range of fuels.
I thought carbie tanks weren't baffled.
Thats why most people run surge tanks.
People run surge tanks on EFI setups not carbie. Thats why carbies have float bowls!!
Its got nothing to do with the tank, its the lack of float bowl and the function it performs (basically a surge tank contained within a carby) in an EFI setup.
Anti-spray foam wont even come close to replacing a surge tank either. It doesn't really provide much in the way of baffling, that's not its purpose.
The foam breaks down as well, in a year or two and costs a pretty penny.
"Replace when foam clogs fuel filter" - Hmmmmm...
There are advantages and disadvantages of pickups baffles, surge tanks and foam
when it comes to fuel supply, all are expensive in the end though.
