It actually looks worse now than it did before... must be a combination of extra tyres in the rear and front springs having to settle again
I reckon you want to think about the back more. If you've still got the TRD lower springs in it give them the flick. If they're designed for road they're probably too hard and with lowering you may have stuffed the geometry of the trailing arms. If you've got some stock AE86 around give them a shot.
When I swapped from choppies to AE86 in mine the difference was night and day. It gave me a heap more traction and made the car more predictable and drive able. Previously, even with the 4K, I spent most of my time looking out the side window and not going anywhere.
Rally guys will tell you to soften the back so it will squat under power, they usually run stock or slightly harder springs on the back with standard-ish heights.
I've also been told to get rid of the rear bar and wind more castor into the front.
Haven't got to that yet, but hope to before my next outing.
Also, if you can get your hands on some second hand rally tyres you're going to go a heap faster too.
P.S. I have AGE envy, that thing sounds awesome. Just what I want and was going to get until my recent speeding fine :abuse:
Edited by snot35
Well its already running swaybar-delete, and there's so much castor the studded tyres are chewing away at the front guards... :P
Edited by 7shades
I agree, much easier to muck with the back at this stage. Will try different springs and see if I can get it feeling more stable. The rear doesn't feel too stiff, but it is much lower than the front.
