This may sound a bit weird, but I had a similar noise to yours. It ended up being the retaining clips that hold the lid of the air filter on. I had tightened the wing nut a bit too much, leaving the clips loose enough to rattle. Although, my noise was fairly constant through the revs. I felt like a right knob after I worked it out haha, thinking it was something bad.
Just thought I'd share on the off chance it was that, probably not though.
all back to gether now and running thank god its manual had to bump start it because somthing is wrong with the starter motor now i just get clickiing noises when i go to cranking
