If I am shortening my front struts, I might as well get another set, so I can build them while still using the car. I just happened to stumble upon a 1982 Cressida at the parts yard. Looks like they should work.
Sweet vented brake upgrade too.
I heat pressure washed them to remove all the oil and brake dust, and stripped apart the hubs and brakes. Brand new brake pads on it.
Spring compressors and an impact drill makes this simple:
Plasma cutter cuts like butter:
And then the grinder to make them a little more manageable.
That's where I'm at with them so far. I have 320# springs for the front, but they are only 7.25" tall. I might have to get some of the same rate in 10". That's all i got for now.
  • Replies 148
What are you doing for steering arms? Just using the cressy ones?
No clue. I'm just winging it for now. If the corolla ones bolt up, ill use them. If not, ill use the cressy ones. If both those don't work... ill design and build some out of some thick sheet metal. anyone know if they are the same bolt pattern? or arm length?
I doubt theyd be the same bolt spacing from arm to strut. You might get lucky with the stock ball joint fitting the arms. If the arms are shorter then you'll get more lock/quicker quicker steering as well.
Here is the measurement from the cressy arm. Anyone with a corolla strut or steering arm laying around want to help me out?
More work done to cressy struts. I chopped out the middle, beveled the edges for better welding.
on the vice, ready for welding. That is the stock Cressida strut inside to line things up.
Weld her up
Then grind down the welds and check for holes: all good!
Shortened vs not
Cut small length of pipe for perch mount. Position so adjust-ability range is optimal.
Bases fitted and welded:
Add some primer and paint:
I assembled both struts, and I did some measuring of my car. From rough measurements, I should achieve about a 3" drop on the front of my car due to swapping the struts. I am not sure how much the springs will compress with the weight of the car on them though. Its a stock te31 and the new springs are 320#. With almost 3 inches already taken off, the spring compression might make my car lower than I really want it. I can opt for 8 or 10" springs for a little more height. As you can see my adjusters are topped out to achieve the height they are at now. With a 10" spring I can bump them up a bit more.
My steering arms look as if they are interchangeable. The Cressida one has 1" longer arms than the corolla's stock, So Ill try to use the corolla ones on the Cressida struts.
This is about the height I am am looking for, but a little higher:
  • 4 weeks later...
I have been messing around with struts again. I tore down the free set of SR5 struts that were given to me to compare some things with the cressida ones. So far I have noticed:
-The original strut tubes are the same length and diameter.
-The steering arms mounting points are wider on the cressida ones,
-and they put the balljoint at a different angle than the corolla ones.
-Balljoints slightly different. <- not 100% sure on this one yet.
So If I use the cressida ones it will suck the lower part of my front tire in bringing positive camber. I can adjust this out by using camber adjusters and it will narrow my track width just a little which would bring my MA61's inside the stock guard. I am not sure if the bigger brakes will push it right back out again or not...
I could always shorten the SR5 struts and retain my ability to run 13" tires. Who knows my Minilites may make their way to my 31. I want to get going on my suspension already, but my car is currently being used as a driver.
I completed the SR5 struts. I made them into coilovers with stock strut tube size, a MR2 sw20 rear struts, spacer, and my 320lbs springs. It is a little- ok ok maybe a lot stiff. This was my test. The springs were free, so I can a buy a set of 10" 270-300lbs and have a better ride. I think I will take a 2" section out of the struts. It seems that my car is about 1" lower on the front with no body roll whatsoever. Pics, sorry some are a little blurry.
I spun down the adjustable perches on my coilovers today. This is the about the level I think I will end up with when I finish my suspension. As for the 320# springs, They settled in a bit and they are really nice. Not as bouncy as I thought they would be. The SW20 rear struts handle them just fine. The car corners very nicely now with minimal body roll.
I am also considering using these. I am in the middle of refinishing them.
I couldn't stand looking at that dent any longer. So i did this, and well, one thing led to another on my first body damage repair job. Soon I'll be able to get some more work done on it.
