ok parts i know i will need are.........
1, motor, .................sorted
2, gearbox (4 or 5 speed at the moment),.............sorted
3, front and rear bumpers,.................sorted
4, ke55 struts and brakes (or some other brake/suspension/stud upgrade),............sorted
5, possibly drivers door,.........sorted
6, lights (and surrounds),
7, tail lights,........sorted
8, grill,
9, matching lock set (ignition, doors and boot),
10, front seats (possibly gti swift or similar),
11, all rubbers (doors, windows, boot, etc)
12, headlining,.........sorted
13, dash pad,......sorted
14, molded carpet,
15, later model diff (matching the front stud pattern),
16, drivers front guard,......sorted
Sexy.
You can polish mine next.
Well bring down your spare and ill polish it for you and can you bring down some fiberglass and resin and mekp as i have to do some fiberglass repair to an outward cowl
hey trevor i have a question to ask........... because i saw that you got some Ke30 struts for your 20.
is it the same suspension system in ke30??????????
i mean can you use the ke30 system in a ke20?????????? :hmm:
Apparently you just have to use the ke20 top "hat" and then it bolts in (at least that is what i have been told and i will let you know for sure when i do it) i am putting these in for the stiffer springs and the bigger breaks
well i got towe's tappet cover and this is what it turned out like
and here is a little finishing touch i did for him
and while i was in the polishing mood my rear bumper went from this
to this
ok ive just had a good days work on the engine bay and it now looks like this
and i got a couple of KE30 grills off zowie and now one of them looks like this
i think i like the custom look of that grill
and i still have to clear coat the engine bay yet
Edited by flyinwall
hey man looks better then it use to :) i got a matching lock set if u still need a set :P? and ive heaps of ke20 bits now and decent prices if u still looking for bits and decent complete interior
6, lights (and surrounds),......sort of sorted
8, grill,...........sorted
9, matching lock set (ignition, doors and boot),............sorted
10, front seats (possibly gti swift or similar),........possibly sorted
14, molded carpet,
15, later model diff (matching the front stud pattern),.......possibly sorted
so at the moment all i need is...
1, carpet
2, all rubbers
3, headlight buckets (what the headlights mount into)
4, external trim pieces
5, drivers seat rails
Edited by flyinwall
