slipn Posted May 10, 2012 Report Posted May 10, 2012 Hello! Pretty sexy radiator has popped up on ebay and since I am in need of one I am considering making a purchase. it is listed as an AE86 one and the seller is not sure if it will fit an AE71 Linkies to ebay item Anyone know if i am in luck? Quote
B.L.Z.BUB Posted May 10, 2012 Report Posted May 10, 2012 Depending on what you need it for motor wise it seems a bit ott. You can run a stock 4age on the standard KE70 radiator. Quote
nz_83_dx Posted May 10, 2012 Report Posted May 10, 2012 (edited) The ae86 radiator will not fit directly into a ae71 without modifications to the radiator mounting points, there are other easier options if your looking for a upgrade. Edited May 10, 2012 by nz_83_dx Quote
slipn Posted May 10, 2012 Author Report Posted May 10, 2012 On 5/10/2012 at 8:44 PM, nz_83_dx said: The ae86 radiator will not fit directly into a ae71 without modifications to the radiator mounting points, there are other easier options if your looking for a upgrade. What are some other options I could look at? Quote
B.L.Z.BUB Posted May 10, 2012 Report Posted May 10, 2012 (edited) What will you be using it for? Engine wise. Edited May 10, 2012 by B.L.Z.BUB Quote
ke70dave Posted May 10, 2012 Report Posted May 10, 2012 id say you are best off measuring the hole you have space for, the ke70 and ae71 have quite a small radiator opening compared to the 86. the factory ke70/ae71 radiator is a dual row core. where as the ae86 one is a longer single row thing. they say that the standard ke70/ae71 rad in good condition is better than the newer type metal core, and plastic end tanks. Quote
