Hi all,
was wondering if anyone on here is running the above and on the street,
If they have a pic and how does the setup hold up, either street, track or drags?
I know it is similar to caltracs, but with coil overs tied to the back of the links
As 4 links can't get passed these days, and looking at options
Leaf spring + coilover Carlos?
Ohwhatanissanfeeling has a photo or two of his caltrac setup in his rides thread I'm pretty sure.
Edited by kickn5k
Two links on the diff, connected to a crossmember welded where the front of the leafs start,
and have a bracket on the links so that coil overs sit on and tie into the OEM spring bracket on the body
You can pick them up at a great price from the engineers,
Majority of applications are heavy v8s
Seeing if someone has it in a rolla
ill be doing a set of caltracs in the near future so ill let you know how they turn out, realy need to stiffen the rear and stop axle trap ,shes sloppy seconds at the moment lol
Cheers ryan, I am aware of caltracs / tramp rods
Just 2 link setup with coil overs,
I know how much adjustment you get with a 4 link setup and how effective it is,
Is the 2 link the similar? On paper it seems it is, but want to know if anyone has or knowledge
The two rods would just stop the axle (or diff) from rolling over and causing the leaves to wind up.
A similar setup
http://www.bigflea.com/corolla/index.cfm?ContentID=109&Nav2ID=7 - and scroll down to Traction Bar (just after Differential Clearance)
The setup uses only the one rod.
Would be able to possibly get some adjustability into the suspension but you wouldn't get the same as in a four-link.
If you can get a pair of coil-overs under the backend, you'll be able to ditch all the extra leaves and just run the big single leaf which is used only for locating the diff. Suspending the diff would come from the coil-overs.
Another option you could look into is a leading and trailing four link. Think of the typical four link setup but the arms replace the leaves, the leading arm starts where the leaves where bolted and connects below the diff, the trailing arm connects to the top of the diff and ends around the same spot where the leaves end at the hangers.
Easier to setup but it will come at a cost of both arms running in different circles causing the diff spin so to speak.
I like that even without coil-overs
thats what I'm wanting to know how it hooks up with coilovers,
I might just look at a 4 link with out leafs, then take the top arms off and leafs back on for street, but wanting some wider rubber up back
your talking to the wrong people,
i know of a 64 falcon getting a 4 link at the moment thats going to be street legal with a 1J.
Have you consulted an engineer?
cheers, andy
Hey Andy,
Yes I have spoken to 1 engineer and 1 fabricator, and awaiting to hear back from 2 others
The car that I'm intending on putting this into advise that they will not sign off on and will requie the necessary fabrication of course which is deemed too extensive, I'm happy to pay for the mods etc and know about the NCOP,
Given that the car is is pre ADR26 (i think??) its a bit conflicting, and getting it on the street might be a problem,
so was looking at the 2 link option, and wondering how people went with this, as opposed to caltracs, i know this works on the same principle and stopping the diff twisting, the pinion in the rolla has hit the floor a couple of times under full power, haha
But with coilovers how does it go off the line
I'd say it'd go a bit better off the line since the diff wouldn't be able to wind up as much (if any).
Neighbour across the street was running coilovers on his falcon ute that he had for sale. But it was for load carrying not traction control.
If it was me, i'd ditch the extra leaves and just use the main leaves for locating the diff and use the coilovers to get the spring rates i want.
But than again on me wagon i've been pondering the idea of ditching the extra leaves, keeping the main leaves, using a similar setup to caltracs and running airbags.
But than again i'm not after performance and speed.
Ok Rob that might be an option, relocate the main leafs towards the diff centre, and use custom coilovers to sit and position in the OEM top brackets, and caltracs on this, seems mini tubbed is lookin more fruitful and get signed off
This is how I'd do it too.
Tubbing the 30 Carlos, or is this your changed circumstance??
