Hi Guys
So i have just put a 7k engine in my rolla, and it seems to be all good, however for some reason, the mechanical advance in the dizzy isnt working!!
The distributor is a 5k electronic type with an internal ignitor, and has just 2 wires coming out from it
The car will start and idle, and we have set the base timing at 15deg, but when you rev the engine up, the timing doesnt advance??
I still have the original points coil with ballast resistor on it which i am planning to change but i don't think that would affect the timing as the car is starting and idling
Should i remove the ballast resistor??
And the vaccum advance is working as well because we did the suction test on that and it does work
Any and all help is appreciated, I am hanging to tune and drive this but this is the onlything holding me back
PLEASE HELP!!!!
Thanks
Andrew
Old efi dizzy's still have mech advance as well last I looked, it's just an electronic signal pickup
and possibly adjustable dwell as well. Check the shaft isn't locked or seized by rotating top
of shaft, it should twist a small amount and then lock up, let go and it should spring back
Ballast must be used with ballast type of coil (so don't remove)
No ballast must be used with non ballast coil (so remove previous ballast)
Don't mix these up!
Must set base timing without vac attached.
Edited by styler
  On 5/8/2012 at 10:09 AM, styler said:
Old efi dizzy's still have mech advance last I looked, it's just an electronic signal pickup
of shaft, it should twist a small amount and then lock up, let go and it should spring back.
That's the easiest way to do it, without pulling it apart.
I'm leaning towards it being locked.
Stu.
Ok so ive pulled the dizzy out and the pulled the top off it, the shaft isnt locked up and the springs and weights all look to be ok (moving freely)
The one thing i will say is that when we set the timing, we did the base with the vac advance tube on, is this the likely cause being that we are trying to set the base with the vac already in play??
my mate thought it might be something to do with the module playing up? I don't know if that would be a symptom or not?
Thanks for all the help so far
Edited by KE ping it real
What happens if you run it w/o the vac on at all and use a timing light to check deg against revs. Then just draw an advance curve on graph paper.
I had this happen when I used too light a spring to hold the weights in, and at the 1000rpm idle it and already advanced through 70% of what the weights were capable of adding. That was when I was re-curving the electronic dizzy to get it to advance faster on The Girls KE70, as the 5K electronic dizzy I fitted had massive springs and never advanced satisfactorily..
You should have say 8deg at idle and another 25deg added by about 2000rpm. When you're accelerating the vac is zero, so you run purely on the weights. When you lift off the vac adds the extra 10deg to burn the lean mixture.
If you set it to 8deg with manifold vac on, say it adds 10deg, then you really have -2deg without vac. That means you will peak out at 15deg instead of 25 with the weights, which will make it flat at revs over 2500. It must show some advance when you rev it if those weights move OK, I think you just have the 5K dizzy problem..
http://www.rollaclub.com/board/topic/42407-the-girls-ke70/page__st__45
Edited by altezzaclub
