TOMsGPTurbo Posted May 3, 2012 Report Posted May 3, 2012 Hey guys, I need to relocate my tow hooks, is there some kind of issue in grinding them off? I'm planning to get one of those racing type ring ones and bolt it to the same section as what the original tow hook is on, but at a higher point, the original tow hooks are in my way. Cheers, Tom. Quote
oldie Posted May 4, 2012 Report Posted May 4, 2012 I wouldnt know if its neccessarily a question of legalities as much as a question of safe and secure tow points determined by the manufacturer regards a position that places the minimum strain/stress on the overall construction of the body in a tow situation.Therefore I would guess that although relocating it would not be recommended by the manufacturer,as long as you are relocating to a similiar and just as secure position but just higher it might not be too much of a big deal. Quote
TOMsGPTurbo Posted May 4, 2012 Author Report Posted May 4, 2012 Thats what was thinking also, but i don't want to write the car off if i drill cut something i shouldnt... after all i hate cutting grinding anything off my car. Quote
towe001 Posted May 4, 2012 Report Posted May 4, 2012 As i found out the hard way one day. Yes, they are needed otherwise the towie will hook the tow line onto anywhere on the vehicle so it can be pulled onto the flatbed. Legal side, i'm not sure. Cause when the vehicle is up on the trailer all thats needed is a couple of loops of rope or chain around the top half of the tires and then tied down. But on saying that it is safer to have the car tied down from the tow hooks. That way the trailers suspension is doing all the work. Quote
orangeLJ Posted May 4, 2012 Report Posted May 4, 2012 I wouldnt be using the tow hook to hold the car down on a trailer, that is, unless you can somehow manage to fully compress your cars suspension.... Straps over two+ wheels, one round the diff to hold it back in case of an emergency, the car should be able to move up and down freely, putting the car weight+trailer weight into the leaf springs of the average trailer is a recipe for an accident over big bumps etc. Quote
B.L.Z.BUB Posted May 4, 2012 Report Posted May 4, 2012 Thats what was thinking also, but i don't want to write the car off if i drill cut something i shouldnt... after all i hate cutting grinding anything off my car. It's steel, whatever comes off can always be welded back on. Quote
Jono.C Posted May 4, 2012 Report Posted May 4, 2012 I don't see the point in replacing perfectly good tow hooks which you know are legal for "racing" tow hooks in virtually the same place... Please tell me there's another reason besides aesthetics? AFAIK you don't even need to replace the stock ones for most forms of motorsport.. Mates have never had an issue anyway, Put it that way. Quote
Jono.C Posted May 4, 2012 Report Posted May 4, 2012 ^ I assume he means those flashy red "drift/ race" ones.. Like this i assume? But weld on Quote
ke70dave Posted May 4, 2012 Report Posted May 4, 2012 well if it is one of those, and it protrudes anywhere outside the panel work, that wont be legal on the road. given that bonnet pins arent, that wont be. (but apparently bull bars are ok....) Quote
Jono.C Posted May 4, 2012 Report Posted May 4, 2012 ^ That's exactly my thoughts! Bonnet pins are no where near as hazardous.. That said though, They do make legal bonnet pins, They're just recessed. But yes, You make a good point about them protruding.. I still can't see the point, Seems a very Pimp My Ride type thing to do.. Quote
ke70dave Posted May 4, 2012 Report Posted May 4, 2012 i belive the point of them is on race cars that are very low to begin with, with possible crazy aero (1" off the ground) they put those things on just under the headlight so the tow man has something to grab hold of when you the belly of the car is sitting in kitty litter 10m from the track. knowone wants to go digging in gravel for your tow hook! makes perfect sense on a track, but yeah don't think you will get very far with it on the road. imagine getting hit by it? man would take a decent chunk out of you. pretty good example on this porche here http://weekendhorsepower.com/wp-content/uploads/2011/08/cms-auto-fair-porsche-gt3-rs-06.jpg Quote
Jono.C Posted May 4, 2012 Report Posted May 4, 2012 ^ I saw that. But that's bolt on, Not weld on as he said.. So presumed he meant the other type Still don't see the point on a street car Quote
B.L.Z.BUB Posted May 4, 2012 Report Posted May 4, 2012 If you run a low front bar that'd have a tow rope hitting it when towed? Quote
