For this i used a broken VT Commodore window regulator which wasn't as good as the VR commodore motors i used in my car as the VR motors used normal bolts and the holes lined up easier you also have to reverse the motors passager VT/VR motor to driver side and drivers side VT/VR motor to passager.
CENTER PUNCH AND DRILL 3 PINS HOLDING WINDER WITH 6MM DRILLBITpost-16116-0-02336500-1335611728_thumb.jpg
ALIGN GEARS TO CENTER TO REGULATORpost-16116-0-42018400-1335612548_thumb.jpg
MEASURE YOUR BRACKETS ON 2INCH WIDE GALV post-16116-0-58713000-1335612484_thumb.jpg
DRILL HOLES 4.5MM FOR SCREWS AND POP RIVETSpost-16116-0-09735500-1335612618_thumb.jpg
  • Upvote 1
  • 6 months later...
hay sorry for the late reply i did have a slight fouling issue by 2mm so i jimmied the motor over in the door fixed the problem and didnt damage anything. i now have to remove the passanger side motor as some dirty person tried unsucessfully to break in to my car but hoping for just a busted wire.
i couldnt see why it wouldnt work with a ke70 but don't have one to try it on so i don't know..
