Ok so heres some pics of the car with the RA65 front end stuff
So went from this
to this
to this!
Although doesn't look like much of a difference in pics compared to real life :(
So you do get a touch of camber with the RA65 with the KE55 arms.
And heres a picture of the whole car this is running the stock KE70 springs up front so with the RA65 stuff it already drops it about 2-3inches.
Edited by It's_AUDM_Yo
So I'll be picking this up along with T50, radiator, fuel pump and etc from a AE86 this Saturday :thumbsup:
Winning.
Why'd you go ke70 springs? Celica ones are stiffer
Well I'm eventually going to go weld-on coilover.
But the reason for putting the KE70 spring in the front for now.
Is the RA65 spring was only a few mm of being double the size diameter of the KE70.
And the strut towers are quiet small in KE70s.
Thus I'm 99% they would hit/rub or not fit in at all.
Edit: Although I am thinking I might give it a good measure when calipers get back from being rebuilt while I have the wheel off.
Calipers got back from rebuild today.
Can't vouch Master Cylinders Exchange enough.
Good bunch of guys and good service.
And them on the car :lovin:
And the massive back clearance :blinks:
And picking up the 4A-GE/t50 etc this weekend :greenbounce:
What did the rebuild cost if you don't mind me asking? Deciding whether to run a kit through mine or get pro's to do it.
Edited by B.L.Z.BUB
It was $189 which is a bit xxxx but its a brand new caliper (basically) afterwords.
They are the most important safety feature of the car so that sort of swung me over to get it done properly.
