Yeah thats it.
I have it will run for a few seconds on the stuff and thats it. Pulled the spark plugs out and all you can smell is the aero start.
Ok so it runs. Have you checked for injector pulse at the ecu pin-our and at plugs?
perhaps it might be worth looking into weather those injectors require the 'little magic box' that changes the impedence of them to suit the ecu. thats about as far as my knowledge extends son the magic box.
i don't recall seeing the magic box in your loom, do you have the little magic box?
They are high ohm injectors so apperently it doesn't need it and the loom didn't have one.
Edited by It's_AUDM_Yo
When was the last time the engine was used?
Measure the ohm rating of the injectors with a multimeter.
Also give the injectors a jump with the car battery to make sure that the coils are moving (one side positive, other negative, you get the idea).
6 months I believe maybe longer.
Alright I'll do that when I next get the chance, How much resistance should it have?
Do the injectors take 12v direct? Could I flood it doing this? or just a quick touch of 12v
13.8 ohms.
Just give them a hit with 12 volts and see if they free up but only if they are stuck.
Alright I'll check next chance.
So quick zap won't break them? I just don't really want to fork out for new injectors.
Got some 100kw injectors here if u wanna try them.
Thanks for the mate I'll PM if I need them
yeah give them a zap.
other thing you can try, get a test light of some description, stick one end on the + side of battery, other side on the injector out pin in the ecu.
i
