Still haven't got the injectors going....Its really flipping my off now.
Both pins at all the injectors have power ,I've checked all the earths and checked there continuity to the ecu.
Also checked the dizzy and all 4 pins have continuity to the ecu.
If anyone has any ideas I'd love to hear them!
Seems like a viable solution at the moment.
Pulled the cover of the ecu is all fine, what the hell else does the injectors need to work?
Also I finally used the guard roller that has been sitting in the shed for months. So no more rubbing....kinda
Edited by It's_AUDM_Yo
There shouldn't be power at both pins should there? One of the pins from each injector is earthed to the inlet manifold and the other pin from each injector joins to the interior half of the loom near the coil and dizzy plugs. Check the second half of post #312 in my thread to see where the injectors get their power from: http://www.rollaclub...d/page__st__300
Edited by rian
Everywhere I've read said it should, It has the right resistance as I've checked it.
I'll check although the injectors definitely have power.
As far as I can tell, bolted down hard.
So the little earth straps are bolted to the base of the inlet mani??
Are the spark plugs dry?
Try spraying some "start ya bastard" in the TB to see if you can get it to fire.
