  On 7/18/2012 at 8:05 AM, It said:
RA65 GT-T(GT-S can't remember no difference in struts/brakes) With HSD coilover kit, 8kg springs and SW20 rear KYB Excel G's.
Be keen for your opinion on them once you've had a chance to drive it. I've been looking into a similiar combo for my ra65 for a while now
Got a louvre stoked! I'm very happy with how the rear looks now. Just needs an exhaust....
Only problem is it hasn't got clips. Anyone have any or know something I can use to hold it on?
Edited by It's_AUDM_Yo
  On 7/20/2012 at 12:31 PM, cicca_294 said:
ha you've got a louvre without clips, ive got clips on my rear window without a louvre...
So post them? ;) haha.
Dang those Enkeis look good.
I'm still cleaning my new 4a lol..but atleaat all my drive line and hydraulic clutch setups already done so iv got that over you atleast haha
You started with a 4AC hey so you got it a bit easier.
Part of the engine loom is looped under the engine mount...
So I'll have to lift the motor a bit and unhook it. The problem is I can't get the engine crane until the coilovers are done.
Let the hassling begin!
Also I've pretty much got the wiring sus'd. So it really should take too much longer now, depending on parts.
Unbolt it and jack it up.
So how did you mate the two halves of the tailshaft?
And what tailshafts did you start with? I've got an S series tailshaft that has had the rear half converted (cut and shut) to T series, and I've also got a standard auto KE70 tailshaft.
I guess I just need to know if they are the same spline where the tailshafts split at the centre bearing.
BTW I very much agree with Will, Enkei mesh is dope.
I started with T50 to T series and K40 to Borgy.
Their is just a single bolt holding them together (near the uni-joint). I recommend getting a shifting spanner of correct size as thread is long and their is barely any room (Took my like 30mins to undo the bastard)
Then the just pull apart then just switch the rear halves round and do the opposite.
I have no idea of splines and etc. I got full spare K40-borgy shaft so hit me up if want that.
Yeah I'm very happy with the Enkei's.
If the auto rear half doesn't fit up to the T50 front half I'll let you know and I might need buy that K40-Borgwarner off you.
