hey everyone, i am doing a 4age conversion and ive run into a problem, i went to bolt the gearbox up to the motor today, and half of the bolts don't seem to line up? its a adm t50 and a bigport 4age, with the dowels that are spose to go in the top of the bell housing, the dowel is on the passenger side top sticking out of the engine, whereas the whole for it in the bellhousing is in the drivers side top, and a couple of the bolts just don't seem to go anywhere? I'm confused, please help
i took a k50 out of my ke70 and the k50 is a one piece with a bell housing you can't take off isnt it? this is one with a removable bell housing and extension housing, ill take some pics when its light time but yeah much confusion
right, just went out and counted some output shaft teeth, and there appears to be 21, also i had a look for some markings on the box and all i found was an old toyota logo on the lower drivers side and 1-2 written underneath it
you've got a "T" bellhousing when you want "A" bellhousing.
Between the two top mounting bolts it has it stamped what motor it fits (5k's don't have anything)
hey i was wrong in my last post, its input has 21 teeth, output has 20, heres some photos to make things make more sense
stud in the back of the motor
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise033.jpg
my bell housing and stud hole thats on the wrong side
extension housing:
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise028.jpg
extension housing
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise027.jpg
the box
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise024.jpg
the box again
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise025.jpg
old toyota logo and some numbers on the box
http://s980.photobucket.com/albums/ae289/htrider/?action=view&current=jdmstcruise026.jpg
Edited by goose101
Reckon you have a T18/Ta22 gearbox, Pics didn't load properly on my computer but the output count seems right as from memory a ae71/86 box has 22? output splines. So it'd have a T series bellhousing if so which is no good for 4age
yep that seems to be the issue, now to hunt down a reasonably priced t50
depends who you are selling too.
chuck it on ebay and you might get some bites.
a mate of mine used one in his austin healey sprite, so their uses certainly arent soley toyota.
