dominating Posted April 6, 2012 Report Posted April 6, 2012 Would 14 X 7.0 PCD: 114.3 Offset: 35 and maybe 14 X 7.5 PCD: 114.3 Offset: 35 work on stock suspension setup then maybe resetting the leafs or blocks and lowered springs in the front? or what would be optimal size for phatty look? Quote
Hiro Protagonist Posted April 6, 2012 Report Posted April 6, 2012 Offset is way too high, the wheels will tuck in a lot and you may have issues hitting the suspension. For that kind of size and width look for at most a +20 offset. As a guide, MA61 wheels are 14x7 +8 and fit perfectly without guard work on standard height suspension and 195 tyres Quote
dominating Posted April 7, 2012 Author Report Posted April 7, 2012 On 4/6/2012 at 10:32 PM, Hiro Protagonist said: Offset is way too high, the wheels will tuck in a lot and you may have issues hitting the suspension. For that kind of size and width look for at most a +20 offset. As a guide, MA61 wheels are 14x7 +8 and fit perfectly without guard work on standard height suspension and 195 tyres So what would your recommendation be getting custom made want to keep stock setup fot now but I wanna go wide without hitting Quote
