yeah, it is bloody slanted. I massaged my transmission tunnel a fair bit but yes, i could lift the rear of the gearbox to level it out.
**they are home made mounts copied from mounts proven to work in two other cars **
The whole crank, gearbox and tailshaft are parallel and the sump clears the swaybar (with a bit of assistance from mr. hammer)
When its all driving nicely i may look at getting my mounts modified to allow it to sit 40mm lower but then the tailshaft will slant more at the uni-joint.
Edited by JC807
  • Replies 146
Car went in for haltech installation on saturday.
I've been convinced to get dual circuit brakes on the car. The missus is stoked.
A series 6 rx7 brake master cylinder has been modified to work with remote reservoirs.
Also getting an adjustable brake bias control.
Edited by JC807
car is running, still in shop though. it needs a GZE crank angle sensor or they can run a disc on pulley and a hall effect pick up.
sounds pretty beasty, can't wait to drive it.
I'd like to think it will be ready next week.
Hey mate, nice work there! That 20's gonna fly, geez it's tight against the wall hey. From my research the GZE cas and the 100kw dizzy have the same internals. If it's running with the dizzy pickups you can always make a custom cover to close it up. I hope it's not suffering from weak signal at high rev's syndrome, that's a pain in the ass, I've even heard of some ecu's suffering from it with a GZE cas :D
Edited by beerhead
hey man , it's looking good mate , i just read through the whole thread and sounds like your a bit ahead of mine , i'll have to get my own thread going for my beast soon , got plenty of pic's now .
How did the S6 RX7 master cylinder go ? was there enough clearence with the manifold/plenum ? i'm very interested to know , i've still got the stock single circut M/Cyl and i think your right , a single circut ain't gonna do the job .
Cheers , Lindsay
the rx7 brake master cylinder was modified by Tweakit to run remote reserviours so as to clear the inlet manifold.
I want to get it engineered.
Can anyone suggest any engineers who are relaxed and cheap? I just want to get the engine and brakes listed really and not have to pay to get steering wheel, seats, gearbox, crossmember, diff, unleaded filler neck, charcoal canister etc. I have a catalytic converter of a nissan GTS-t.
got the car back, goes like stink. :y: :) :y:
have a few bits and pieces to do now:
put my other gauge cluster in, with tacho and make the old cable clutch hole big enough for the speedo cable.
get a catch can, the 1.25l bottle doesn't look too good.
get some longer wheel studs for the front so i can run the fwd stockers for a while until i get the suspension all sorted out.
I have new bushes all round but the shocks and springs are really crap. If i get lowered suspension i may have to get the exhaust redone to go under the diff :(
  • 5 weeks later...
  • 4 weeks later...
no still not engineered, i need a catch can arrangement of some sort. I used a VH44 remote brake booster, rx7 m/c with remote reserviours, and ke55 front brakes.
  • 7 months later...
