Well my corolla had a v6 supercharged engine with different diff and auto gear box,
Now thinking about putting a RB 30 into it just wondering if anyone has done it and what mods you have to do.
like
best diff??
gearbox to fit onto the rb 30
if R31 struts and brakes would go straight in ??
if anyone has a RB30 55 crossmember??
any info you have would be much appreciated. cheers WebRepcurrentVotenoRatingnoWeight
Edited by bperkins11
like
best diff?? Hilux diff should suffice or if you buy a whole R31 and can use the engine, gearbox and diff out of that with minor mods to the diff.
gearbox to fit onto the rb 30 An RB30 gearbox I would think?
if R31 struts and brakes would go straight in ?? Yes they should do if you use the whole lower control arm (might need to measure and possibly use S13 lcas), and might be able to use the R31 strut tops but if not easy enough to just put the KE55 tops onto the R31 struts
if anyone has a RB30 55 crossmember?? Dought anyone would have one to bolt it straight in but wouldn't be hard to make the crossmember work with the RB.
Mate ive just fitted a rb30t to my ke20 i no its not a ke55 but close and there is alot of cutting and moding everything but good luck they look sick when in there
My 55 us to have a 1jz in it with modified tunnel and firewall, but standard crossmember, depends where the sump is located u might get away with it
  • 2 months later...
  • 4 weeks later...
